1971 LT1 AX emissions label
Re: 1971 LT1 AX emissions label
The original 71 label is printed in reverse on the back of acetate then flood coated white then adhesive applied.
The layers from outer most to what is glued to the firewall ARE as follows
Acetate
Black print
White flood coat
Adhesive
Having the print UNDER the protective acetate keeps the printing from being scratched or removed by brake fluid etc.
Most glues will remove the original black printing and the white coat too, however SUPER GLUE WILL NOT, so if you have an original which is starting to lift... use a dab of superglue to hold it down.James A Groome
Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453- Top
