1966 & 1967 with A/C (&C60): Upper Radiator Support/Shroud Seal - NCRS Discussion Boards
  • Ray K.
    • April 30, 2005
    • 401
  • Mike B.
    • July 31, 1994
    • 838
    Re: 1966 & 1967 with A/C (&C60): Upper Radiator Support/Shroud Seal
    Here ya go Ray,
    Only have a photo of a '66-'67 upper radiator support seal. AIM item #2. Same seal for big and small blocks. The lower fan shroud seals and lower radiator support seals are different for big and small blocks. See the AIM drawings here on C60 sheet B2.5.
    Mike
    '66 AC Radiator Support & Fan Shroud Seals.jpg'67 Upper AC Radiator Support Seal (top).jpg'67 Upper AC Radiator Support Seal (bottom).jpg
    • Ray K.
      • April 30, 2005
      • 401
      Mike,
      Thanks for the info. It helps a lot!!!
      Ray K
      • Mike B.
        • July 31, 1994
        • 838
        You're welcome Ray,
        Gotta give credit where credit is due. These 2 photos of the upper radiator support seal were taken at John Richter's shop. I think the seal was removed from his '67 L36 AC coupe.
        Mike
        • Ray K.
          • April 30, 2005
          • 401
          • Mike B.
            • July 31, 1994
            • 838
            Sorry Ray but I only have the current '66 JG & TIM. Maybe someone with the '67 manual will chime in.
            • Harry S.
              • July 31, 2002
              • 5258
              Ray, I know the seal was not made for a 63. I purchased one, trimmed it to fit and it snapped on.
              Has been working fine.
