I'am building an engine for my '65 327/300 using New and old parts "all original" and my airfilter does not fot, it seems like I'am 1" short of my carb, looks like it need a 1" shim.
Can anyone tell what I'am doing wrong?
In the next pop-up window, choose the image using the Browse button. After you select the image with Open, you will need to click Upload File(s). Screenshot 2023-06-26 at 7.55.14 AM.jpg
Help wanted for my non fitting aircleaner, it does not fit on my carb, I'am building an engine for my '65 327/300 194675S104084 with new and old parts all original, when I try to put on the aircleaner it seem like I need an 1" shim.
The crankcase vent tube is to high so my arrestor won't fit correctly.
Would you mind posting a pic of top and bottom sides of the air cleaner base and the complete top of the carburetor?
Owen, I agree we need more information. I'm a 63 guy not 65. Looks to me like the wrong air cleaner, too thick. Manifold? Carb?
Think we need all he casting numbers and many more pictures.
There was a Corvette forum thread where the photo looks just like yours (from the looks of the avatars, Harry commented then too):
Originally posted by SWCDuke
Due to a different air horn diameters for the 250 and 350/365 HP engines they had different bases and maybe different tubes, so there could have been as many as three for '65. Check you AIM. You might have the incorrect part for a 300 HP engine. I agree that the photos look like the same part, so maybe you have the wrong air cleaner base.
There are lots of errors in parts catalogs, both GM and aftermarket.
Originally posted by Twan Baars (44079)
[ATTACH=CONFIG]117526[/ATTACH]
Here's a pic of an original on eBay. Seems the length from the bracket through the upward curve to the hose stop is much shorter than what you show on your engine. 22s-l1600.jpg
[ATTACH=CONFIG]117533[/ATTACH]
Own and Twan------
There were 3 different tubes used over the 1964-65 period but I do not recall how they differed in configuration. The one used for this application was GM #3846110 which was discontinued in 1977. 1965 with L-76 and L-79 used a different tube.
