Driving cars on plant property
Assembly plant drivers instuction
Re: Assembly plant drivers instuction
Hi Ralph - and where were car assembly plants 8 and 16 ?
Speaking of "driving" - I spent a fair amount of time in assembly plant toe-in pits and the area between the final line driveoff and the pit was a very dangerous place to be.
After engine start, Drivers would typically slam them into gear (most were automatics) at the same time they were stomping on the gas...and you thought your car was babied before it left the plant - NOT !
the driver's side door was held open and most drivers would dangle their left leg between the open door and the rocker...
Speed to, and then harsh braking at the pit were both excessive (IMO)...all designed to save fractions of a second so more time to "rest" after bailing out...
and yes, a few were wrecked before they ever left the Plant...thx,
Mark- Top
At the Fort Wayne Truck Assembly they would get in the new trucks & floor it over the offset speed bumps to align the bolts & panels at least thats what I was told. They drove a truck off the line every 56 seconds. Friend was a electrician there so I got to see everything.65 350 TI CONV 67 J56 435 CONV,67,390/AIR CONV,70 454/air CONV,
What A MAN WON'T SPEND TO GIVE HIS ASS A RIDE- Top
Hi-In reference to procedure F- I ordered my 69,and was present when it was delivered from St. Louis to central Ks. via Jackie Cooper Semi-Transport. After taking delivery and arriving home, I found two used paper coffee cups and sandwich wrappers in the Jack Stowage Compartment.
The coffee cups had 4 poker playing cards printed on the sides,with the "hole" card printed on the bottom.
The sandwich wrappers were wax paper.
I ruled out the dealership as the culprit, because it was very small,and did not have a coffee vending machine; and I did not see how the transport driver could have done it either, so I have always felt that someone at the factory was responsible. (There was a lengthy U.A.W. strike that year, and I am sure there were plenty of unhappy workers on the lines.)
By the way- Do you think W.J. Mitchell could be THE Bill Mitchell?
E.J.- Top
To the question of W.J. Mitchell is THE BILL Mitchell... THE Bill held the position of VP of Styling at GM from about 1958 to 1977. His middle initial was "L", not "J". Good thought though!Bill Bertelli
Northeast and Carolinas Chapters Member
'70 Resto Mod LT-1 w/ partial '70 ZR-1 drivetrain- Top
- Top
At the plant in Framingham Mass.they built Cutlass, Chevelle. Pontiac , Buick in the sixties the guys that drove the cars off the line and parked them in the lot on the overnight shift used to take the cars out on the road in front of the plant and drag race.- Top
At the plant in Framingham Mass.they built Cutlass, Chevelle. Pontiac , Buick in the sixties the guys that drove the cars off the line and parked them in the lot on the overnight shift used to take the cars out on the road in front of the plant and drag race.thx,
Mark- Top
