I recently gravity bled my brakes on my 67, primarily just to flush out old fluid. I am glad I did this apparently I had a little air in the system because I have a much better pedal now than before. I thought my pedal was fine before but much better now. The fluid that I drained out looked like tea was pretty bad.
67 Gravity brake bleed
Tags: None
- Top
Re: 67 Gravity brake bleed
Lawrence: Thinking of doing the same to my(C2)- 66 Convertible. Brake fluid is DOT#5. Thinking I also have a
little air in the system. CAR HAS KNOCK OFF WHEELS. Question for anybody> Can I gravity brake bleed the
system WITHOUT TAKING THE WHEELS OFF?? Need advice please>LarryLarry
LT1 in a 1LE -- One of 134- Top
You have to remove the wheels to get to the bleeders. I used Dot 3 fluid in my car.- Top
No you can't. To access the bleeders, the wheels must be removed. Also, don't forget there are two bleeders on each rear caliper...an inner and an outer.Lawrence: Thinking of doing the same to my(C2)- 66 Convertible. Brake fluid is DOT#5. Thinking I also have a
system WITHOUT TAKING THE WHEELS OFF?? Need advice please>LarryLeif
Top Flight 2017 Lone Star Regional- Top
