C1 58 Gas Door Assembly Hinge Pin - NCRS Discussion Boards
  • Jason P.
    • April 6, 2023
    • 207
    I have both parts of the gas door assembly (the door and the hinge). Is there a pin of some sort that is used to connect the two parts together? I am having trouble figuring out how the 2 parts are supposed to work together without a pin for the hinge.
    I don't see a hinge pin for sale anywhere and was wondering what others have used as a pin to keep the hinge together.
    THanks,
    Jason
  • Dan H.
    • July 31, 1977
    • 1365
    Re: C1 58 Gas Door Assembly Hinge Pin
    Jason, look on Ebay for 58 gas door, Corvette Central has a new one and good pictures of hinge side, looks like it's spot welded on,
    or is it where the rod slides through? Might be a simple Home Depot bulk rod, Dan'
    1964 Red FI Coupe, DUNTOV '09
    • Steven B.
      • June 30, 1982
      • 3976
      As Dan noted just get some rod/wire and insert through the two pieces.
      • Jason P.
        • April 6, 2023
        • 207
        OK thanks. I will look for some rod/wire at Home Depot.
