I am Restoring a 1968 convertible from a frame , body and the rest in boxes.
I have two windshield outer top header mouldings. They both have the same 90deg return on the rear side with the same cut out's and holes for U clips.At the front side they are different.
One has a 5/8" 90deg return with 4 3/16" x 1/2" slots and 4 open angled slots.
The other has a 1/8" x 1/8" double return with 6 open 1/8" x 1 1/2" slots.
So the question is , which one if any is correct for the car, build date is 4 - 17 - 1968.
Thank you John.
Thank you John.
