C2(66) Big Block Radiator Brass Plug Question - NCRS Discussion Boards
  • Larry E.
    • 1652
    Re: C2(66) Big Block Radiator Brass Plug Question
    Larry-------
    I believe the taper for the NPT thread is exaggerated in the diagram. I don't think there would be that obvious a difference between NPT and NPTF in "real life", especially in the case of 1/8" . Also, NPTF is not straight thread; it is tapered.
    Joe: I am sure you are correct. Diagram was probably made to show there is a difference but not in correct scale. That being said I did
    compare my original plug (believe it to be NPTF) with the plugs I bought from Corvette Central(See Above) and saw that the
    C/C plugs where visually a little bigger. Thanks Again>Larry
    Larry
    LT1 in a 1LE -- One of 134
