�65 FI fuel leakage - NCRS Discussion Boards
�65 FI fuel leakage
  • Michael G.
    • November 12, 2008
    • 2155
    �65 FI fuel leakage
    No sooner got home from Duntov judging than one of the nozzle blocks on my ‘65 is showing signs of fuel leakage. No liquid is evident, but there is significant staining on the base plate below the driver’s side rear nozzle block. I’ve driven it about 3 hours since it was completely clean, with a slight fuel smell in today’s 40 minute ride .
    I can tighten the nozzle block bolt, but I don’t know the torque spec (if any). Any advice would be great.
  • Don H.
    • December 1, 1981
    • 1482
      • May 31, 1974
      • 8365
      • Michael G.
        • November 12, 2008
        • 2155
        Originally posted by Mike McCagh (14)
        rotate the brass fitting on top the nozzle itself, counterclockwise just enough to free it up finger loose, then gently retighten the brass fitting with a short (less than 4" long) open end wrench. don't over-torque on the brass nut or u will split the nut and then you will have a significant leak. gently mike, gently tighten the nut. mike.
        • Don H.
          Moderator
          • June 16, 2009
          • 2236
          good practical advice from someone who has been there, done that, for a good many years.
          • Michael G.
            • November 12, 2008
            • 2155
            • John D.
              • December 1, 1979
              • 5507
              • Michael G.
                • November 12, 2008
                • 2155
                • John S.
                  • May 4, 2008
                  • 424
                  John Seeley
                  67 Black/Teal
                  300 hp 3 speed coupe
                  65 Maroon/Black
                  35k mile Fuelie coupe
                  • Michael J.
                    • January 27, 2009
                    • 7073
                    WillyAtWork.jpgI agree Fuelie John, but my fuelie guru is Bill Wilhelm, he has done 4 for me and he knows all there is to know about Rochester FI units. Here he is at work.....
                    • Michael G.
                      • November 12, 2008
                      • 2155
