Re: 69 vacuum advance for L71
Duke-
I have the 3:08 rear end with posi. I think the 3:08 and the automatic tames the L-71. It’s not a beast at all to drive, in fact, it’s not any more wild than my 1995 LT-1. Really a lot of fun with the tri-power and not having to shift around town. Very thumpy cam in drive when you’re just idling around like in a parade. Of course on the road is a different experience. Hot, rough ride and noisy! AC was not an option with the L-71 automatic.
Not sure what the stall speed is maybe around 2500 RPM?.. I don’t know a lot about the TH400 other than it is HD compared to the others offered on the milder engines. I also remember reading that the torque converter has 6 bolts so it’s HD. If anyone has information please post.
I set the initial timing to 8 degs with the VAC plugged off and around 750 RPM so that is below the speed the centrifugal starts.
I was able to do a little testing today. Before I converted to full time vacuum and initial timing at 8 degrees I was running initial timing at 12 degrees and no VAC. So I am not sure if some of the difference I noted was do to the change in initial timing or the VAC.
I only had a little av gas and 91 octane mixture left so I could not do a lot of street testing. It did seem to accelerate better with more power from WOT start and low speed response but I didn’t see any obvious difference at higher speeds. I don’t like revving it more than 3500 RPM. It’s a numbers matching engine and I am a little nervous that I might damage it. Maybe I am more cautious than I need to be.
I simulated the parade route to see how hot it got. I was running 210 degrees at the end of the route which should be safe but it was only 83 degrees today. I am going to get more fuel tomorrow and test it again. It is supposed to be in the 90s so that will be a better test. I am wondering why my total advance is only 19 degrees (8 degrees initial timing plus 11 degrees VAC). If I could get the full 16 degrees VAC maybe it would run cooler.
I did experience a nasty backfire when I when to WOT from 35 MPH. When I was running without the VAC and initial timing set at 12 degrees I had to reduce my accelerator nozzle a couple sizes because I had a hesitation at WOT. Reducing the shooter size was the only way I could eliminate the hesitation. So I am thinking maybe it was a lean backfire caused by the small shooter. I replaced the smaller shooter with one size larger and didn’t get any backfires but I didn’t do a lot of tests. I’ll do more WOT testing tomorrow.
Duke-
