67 rear quarter behind wheel well coating - NCRS Discussion Boards
  • Keith B.
    • December 1, 1991
    • 397
    Keith Burmeister
  • Mark F.
    • July 31, 1998
    • 1468
    Re: 67 rear quarter behind wheel well coating
    A photo would be helpful.
    Per John Hinckley's C2 Assembly Process Presentation (available in the Database of Restoration Documents [DoRD] Sticky Post), here's all he says specifically relating to wheel wells (both of these in the paint shop prior to body drop):
    After final bake, body was moved through a transfer area to the Black-Out Spray Booth, where the engine compartment, hood underside, cowl plenum cavities, and a large cardboard spray mask was used for the hood underside application, but no masking was used along the front edge of the hood inner panel.
    Wheel well air-dry sound deadener/undercoat material was applied after the final bake oven and the black-out booth, with airless spray guns fed from 55-gallon drums; no masking or shielding was used, and care was taken to keep the material off exterior surfaces and away from the #3 body mount access hole.
    thx,
    Mark
    • Gary B.
      • February 1, 1997
      • 6979
      Keith,
      For calcification, are you referring to the area on a 65/66 where the power antenna body is located? That is to say, the compartment aft of the rear wheel well proper?
      Gary
      • Keith B.
        • December 1, 1991
        • 397
        Yes that is the area I am referring. It is a 67
        Keith Burmeister
        • Gary B.
          • February 1, 1997
          • 6979
