Best way to remove DOT markings from rubber fuel and brake lines - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1387
    Guys,
    I'm trying to remove the DOT markings on my fuel and brake lines for judging purposes. I was thinking of using some paint thinner but wondered if that would weaken the rubber? Is there an optimal way to remove these markings?
    Mike
  • Chris H.
    • April 1, 2000
    • 837
    • Leif A.
      • August 31, 1997
      • 3607
      Re: Best way to remove DOT markings from rubber fuel and brake lines
      A quick wipe with lacquer thinner or acetone will take them right off. You're not going to be soaking the rubber...you'll be fine.
      Leif
      • Paul Y.
        • September 30, 1982
        • 570
        I use brake fluid. It will not harm the rubber hoses and it sure will remove paint and ink and dye.
        It's a good life!
          • 15610
          A rag dampened with acetone.
          • Michael J.
            • January 27, 2009
            • 7073
            Yes, much easier than grinding off the DOT numbers on tires and making it look original.
            • Gary B.
              • February 1, 1997
              • 6979
              • Gary B.
                • February 1, 1997
                • 6979
                • Gary B.
                  • February 1, 1997
                  • 6979
                  John,
                  Yes and no. The double crimp differs from the original single crimp. But there is no deduction for the double crimp per se.
                  Gary
