1.25 inch vs 1.5 inch tire valve which is correct for '69 - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1387
    Guys,
    I'm setting up a set of wheels/tires for future judging purposes for my Sept '69 built L-46. My car originally came with white stripe tires with the PO2 wheel covers. I've found two different types of valves from the various vendors: 1.25 in or "short" valves vs. 1.5 in or "long" valves. Which would be correct for my car?
    Mike
  • Gary B.
    • July 31, 1979
    • 926
    Re: 1.25 inch vs 1.5 inch tire valve which is correct for '69
    From the wheel to the tip of the threaded stem, they measure roughly 1-5/16" tall.
    P02 hubcaps used valve stem extensions, with a white tip. They measured roughly 7/8"long.
    68-69 TIM&JG, 6th Edition, Page 98, Figure E 21.15 and E 21.18.
    Gary B
    • Ralph S.
      • February 1, 1985
      • 935
      Do you find the correct valve extensions and what are they worth
      • Leif A.
        • August 31, 1997
        • 3607
        Are these what you're looking for??
        1968-1973 Corvette P02 Tire Corvette Valve Stem Extensions at Zip at Zip, the source for C3 Corvette reproduction tires, steel wheels, trim rings & center caps.
        Leif
        • Jeffrey S.
          • May 31, 1988
          • 1879
          These valve stem extensions will certainly be functional but the conventional wisdom is that the "correct" extensions have "SCHRADER" embossed on the black plastic and a hoie in the center of the white plastic. Of course, GM probably used several vendors for these so other types might be also acceptable. I have several sets in the shop and I will try to post a picture later today. Pages 98 and 99 of the current judging guide have several pictures of the variations
          Jeff
          • Michael L.
            • December 15, 2006
            • 1387
            Yes I have the valve extensions that you posted above my question was about the valves themselves it seems like two versions are available it sounds like the correct ones are the ones that are listed as 1.25 inches.
