The OE part number is 1115236 and the nominal specs are start @ 4" Hg, max 16 deg. crank advance at 8", and this VAC necessary for engines that idle at 12" Hg or less in neutral if a manual trans, and DRIVE if an automatic if they have full time vacuum advance. This will ensure that total idle advance is "locked" at idle speed. Otherwise, if there is not enough manifold vacuum to keep the VAC locked at full advance, total idle advance will be lost, which will further reduce manifold vacuum causing more idle speed loss and so on and so forth until the engine stalls.
GM stopped producing VACs for the single point and HEI distributors in the nineties, but Standard Motor Products has produced most of them since then. They are available in numerous "brands" including Delco, but all are manufactured by SMP and carry a unique ID for their various specs. A dozen or more may still be available, but ONE of the following three will be best fit using the Two-Inch Rule for any engine with full time vacuum, and they are the 8" B28, 12" B26, and 15" B22.
In recent times the B28 has dried up in most brands and the last remaining stock as of a couple of years ago was the Airtex 4V1053. But now this part has become the WVE 4V1053, and there are many reports that it doesn't meet spec, specifically requiring materially more than 8" Hg vacuum to pull to the limit.
So I did a simple web search "WVE auto parts", and got their Web site, https://wellsve.com/ ,wrote them a note about the problem and what happened to Airtex. It's tough to keep track of all the acquisitions/mergers in the auto parts industry. Here's the rsponse:
Hi Duke.
Thanks for reaching out. Wells and Airtex unity predate me. We do still get some folks that are looking for Airtex info.
Yes we have had several inconsistencies on the part number 4V1053 and its specs. This is something that was conducted some time ago however, it does take time to sort out completely. The verified parts have a stamping on the plate of "B28".
Hope this helps.
Dan Shreve
Technical Services Advisor
Wells Vehicle Electronics
So it looks like they understand the issue and are working on it. Rock Auto may be the best source, and they have a good return /exchange policy. See this nearby thread about a quest for an in-spec B28:
https://www.forums.ncrs.org/showthread.php?132872-69-vacuum-advance-for-L71
Hi Duke.
Hope this helps.
Dan Shreve
