'54 steering wheel problem - NCRS Discussion Boards
  • Brian W.
    • September 30, 1990
    • 216
    I removed the steering wheel ad repaired the signal light switch and all is back together. Problem being I can't get the horn to stop blowing and it blows all the time. The signal lights and brake lights are working fine. Is there an adjustment I can do to stop the horn and get it to work properly.
    Brian
  • Chris S.
    • January 1, 2000
    • 1064
    Re: '54 steering wheel problem
    You have the steering wheel horn too tight - the screws for the horn honker
    back them out about half way
    Reassemble
    It might take a couple tried to get it
    Chris Sherman
    TiN Restorations
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Brian W.
      • 216
      Chris. that worked great. I never thought of backing those screws out just figured they should be tight.
      Brian
      • Chris S.
        • January 1, 2000
        • 1064
        I did too my first time
        Then you connect the battery and OH HOLY LOUD
        If you need any help let me know
        Chris
