I have a local Corvette friend that needs guidance on what lubricate should he use when he changes the rear end lubricant on his '69 390 hp 4 spd.
'69 rear end lubricant
Re: '69 rear end lubricant
.............................Attached Files- Top
- Top
Buy the AC Delco differential oil #10-4016 (2 bottles) and Positraction additive #10-4003 (2 bottles) -- both available at your local GM dealer, local auto parts, Amazon, Summit, etc. Squirt 1/2 bottle of fluid into the diff, add both additives to the bottle, shake it a bit and empty the bottle into the diff. Add the second bottle until the fluid seeps out the fill threads. Be careful to use a long nozzle straw so that if it comes off the bottle it's not lost inside the diff housing...
- Top
My 1963 Corvette Shop Manual, page 0-7, states the recommended lubricant for the T-10 and axle is"
"Lubricate with SAE 80 or SAE 80-90 Multi-purpose Gear Lubricant meeting the requirements of U. S. Ordnance Spec, Mil-L-2105B."
HELP! Does anyone know where I can find some?
Duke- Top
