This morning all 4 tires register as 0. Actual pressure is 30 psi in all. Any suggestions as to causes or solutions will be helpful.
2010 Tire pressure sensor problem
Re: 2010 Tire pressure sensor problem
John,
Any work done on the tires recently? Could be the batteries in the TPM, they have a typical life span of 5-7 years. Seems unlikely that all four would go dead at the same time. I would drive it for a while and see if it doesn't rectify itself.Leif
Top Flight 2017 Lone Star Regional- Top
John,
Did you try re-setting your TPMS? On all four tires?
If I remember correctly, the instructions are in the owners manual.
However, I can't remember if the 2010s require a TPMS reprogramming tool . . . .
If it does (and you don't have one) you can take it to your dealer and they should be able to do it for you.
Ray K (#43777)- Top
Try disconnecting your battery for 10 minutes and see if that resets the TPMS.
Mike- Top
Interesting thing happened today to my 2021. After a software update download and installation, the TPMS went blank. There is a setting in the "Tire Pressure" menu to "Relearn", I am trying that now. These modern cars with all the electronic gadgets can be a real PITA.Big Tanks In the High Mountains of New Mexico- Top
