Does anyone know the dimensions and finish of washer 1371261
Washer 1371261 finish and dimensions
- Top
Re: Washer 1371261 finish and dimensions
If you say so...sorry for trying to help. If you don't know the dimensions, how can you be so sure those posted are incorrect?Leif
Top Flight 2017 Lone Star Regional- Top
Joseph,
Over the years I have purchased many items from AMK, and in the vast majority of cases when they say something is zinc, they are correct. For the washer in question I suggest you contact Rich Pasqualone, whose contact info can be found in the archives. If he doesn’t have any of those washers, he’s still likely to know its finish and approximate thickness.
Gary- Top
Does this make you any more comfortable? From Corvette Central...
Includes:
5/16 Split Lock washer- Zinc
5/16 -18 x 1 Hex Head Bolt
5/16 USS Standard Flat washer (3/32 Thick)
Leif
I think you are looking for the alternator adjusting bolt and washer.
The star washer is 9 tooth.
The finish of the thick washer is zinc
CBE4300D-F01E-42E5-9125-308BDD3B662F.jpgBE383A6A-F62B-4164-BDB9-34851D18CD69.jpg8DC5AA5A-5B09-43D9-B906-9A9F8A6346B8.jpg- Top
If you are looking for the alternator adjusting bolt, lock washer and flat washer have asked that question before, here are some comment from original cars and note that different years had different set ups
Small Bolt, 64AIM
Bolt 122017
SPL Washer 3792420
L Washer 187119
3792420 Spl Washer info
ID OD t
RJ .340 .875 .095 measured
MH .335 .875 .085 from his 66
HS .32 .51 .06 on his car,
Lindahl .375 .875 .125
Lindahl .31 .88 .09 AC kit for 64 has same washer
AKD .344 .8795 .0975 on car
65 Alt .349 .8780 .1115 AKD has
Sorry, worked on formatting for 30 min now and what shows up in preview is not what is written, think you can figure it out
Alan- Top
Leif
Good point Gary, I just copied from the AIM (63-65) which is the same part, 3792420, for those years.
Note at one point the "split" lock washer, 187119, appears to have changed to an external tooth washer??
That's why we need to know the year car, please.- Top
Gary,
Thank you, will update my file.
Did you check to see if the "split" lock washer, 187119, change to an external tooth washer during the C2 years?
I too only have a limited number of AIM's
Alan- Top
