67 aluminum wheel starburst caps
Re: 67 aluminum wheel starburst caps
Chuck,
The first design center caps had an "HC" stamped on the backside. Later service replacement caps had a PMC stamped on the back. The HC caps had a deeper red than the PMC caps. You can easily mask the cap off with painters tape and reshoot the red inserts. The key will be getting the correct hue of red spray paint. Clean them well, zinc chromate prime (thin coat) and shoot two LIGHT coats. Voila. Back to new. Good luck. ARA- Top
