Need tropical headmark and grade for �66 �shipping bolt� - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 6979
    Does anyone know a headmark, typical for ‘66, and the bolt grade, for the bolt described in the AIM as a “shipping bolt”, labeled with a triangle 4 torque spec at the right in the AIM sketch.
    Gary
    PS I assume RSC, RBW, or TR, would be fine, but I can’t guess the grade, other than it’s not likely to be grade 8.
  • Ed S.
    • August 6, 2014
    • 1377
    https://www.forums.ncrs.org/showthre...=shipping+bolt Hope this helps.
    Ed
    • Gary B.
      • February 1, 1997
      • 6979
      • Ed S.
        • August 6, 2014
        • 1377
        Ed
        • Mark F.
          • July 31, 1998
          • 1468
          Gary,
          Why is the bolt necessary for "shipping" ?
          I understand there's a hole in the block there, but is it removed and something else attached at the Dealer ?
          Sorry for being dense, but I can't envision what would fit in that small space next to the fuel pump.
          thx,
          Mark
          • Mark D.
            • June 30, 1988
            • 2142
            Kramden
            • Ed S.
              • August 6, 2014
              • 1377
              Ed
              • Mark F.
                • July 31, 1998
                • 1468
                Originally posted by Ed Szeliga (60294)
                Good question - if you did a search through the threads of this forum there appears to be several plausible explanations of the "shipping bolt". One is that Chevy cars in the late 1950s had a motor mount that was secured to the block with a bolt that went into this threaded hole. Another explanation is that a "rack" used to move the block in the factory was bolted to the block with a fastener though this hole. And then of course, there is the "plug the hole with the short bolt but if you need to change the fuel pump insert a long bolt to hold the push rod in place when you remove the pump" explanation. All three might be correct, some more than others. Here is a link to a thread that addresses all three purposes for the "shipping bolt". https://www.forums.ncrs.org/showthre...=shipping+bolt
                Thanks, Ed !
                I feel better I'm not the only one who didn't understand what this was for...
                The link you provided covers the possibilities really well !
                thx,
                Mark
