I am going to service/rebuild my standard steering column and will follow the AIM, 63 Shop Manual and the Steering Column Components document from Dave Zuberer.
Would most recommend replacing functional original parts with reproduction parts since those original parts are approaching 50 years old ? I want to avoid introducing new problems into my restoration because when I took it apart everything worked well.
Are there any other sources for the upper and lower bearings than what is available from CC, ZIP, Ecklers, etc ? Anyone have a US bearing they can recommend ?
Since all the rest of my wiring was replaced then I am thinking of installing the Lectric Limited turn signal assembly sold by CC with the upper bearing and column harness included.
My coupler reference marks when I took apart everything 10 years ago did not survive due to rust on the steering shaft. What is the best way to determine which spline position to install it ?
In Operations my horn didn't work at the 9 o'clock position. Would replacing the horn contact assembly usually fix that ?
Mark
Mark
