Hi, my engine that is going in my 58 Corvette is not the original engine. It is a 327 and I am looking for advice on what I can do where I have clearance issues with trying to install the upper radiator hose to the intake manifold water neck. The oil filler tub is too close to the water neck to allow the hose to go on.
Can I move the oil filler tube out of the way a little bit? If I can, how would I go about doing that safely?
I was thinking about inserting a large pipe (about the same diameter as the inner diameter of the oil filler tube) and trying to gentle wiggle it to see if I can make more room for the hose to properly fit.
Any advice is appreciated.
Jason
Jason
