Error in 64-67 AIMs; RH wires from spark plugs to distributor cap towers - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 6979
    • Jack M.
      • March 1, 1991
      • 1138
      Re: Error in 64-67 AIMs; RH wires from spark plugs to distributor cap towers
      Yes, Gary... if you recall, I was the one that sent you that 1968 AIM page.
      What I'm referencing is the 1964 AIM REVISION... someone ordered that wiring update.
      Unfortunately, my 1964 copy is hole punched directly on the revision date.
      I'd guess itz Aug or Sept of 63... wishing, but doubtful anyone has that specific ECR.
      • Gary B.
        • February 1, 1997
        • 6979
        #18
        • David K.
          • September 30, 1979
          • 238
          #19
          The revision date is 9/5/63
          Dave
          • Con X.
            Infrequent User
            • April 1, 1992
            • 23
            #20
            Appreciate your bringing this up. I'll be reassembling soon (I hope).
            • Jack M.
              • March 1, 1991
              • 1138
              #21
              THANX to all, for provided the proper date.
              • Gary B.
                • February 1, 1997
                • 6979
                #22
                Thanks all.
                Gary
                • Dave P.
                  • June 30, 1991
                  • 184
                  #23
                  I'm not aware of any reverse rotation distributor small block ever produced by GM.
                  You're correct, there are no reverse rotation distributors but there are most certainly reverse rotation engines, mostly in marine use.The distributor still rotates CW (so the oil pump is driven in the correct direction) but the firing order of a reverse rotation engine is reversed.
                  Jack's "1964" pic depicts the correct firing order and plug wire placement for a reverse rotation engine. The distributor still turns clockwise.
                  I've worked on dozens of reverse rotation marine engines. The firing order is 1-2-7-5-6-3-4-8. Rather than memorize the reverse firing order, I just use the 'regular' and run it CCW around the cap. Like Jack's picture.
                  Chris-Craft was a major customer for Chevrolet marine engines and began producing large numbers of twin engine cruisers in the early 60s. The twin installations typically used one standard rotation and one reverse rotation engine. I wonder if the reverse engine firing order drawing was produced for this configuration, but erroneously was incorporated into Corvette documentation? Just a thought.
                  • Gary B.
                    • February 1, 1997
                    • 6979
                    #24
