Bolt Size for #4 Body Mount - NCRS Discussion Boards
    Re: Bolt Size for #4 Body Mount
    Originally posted by Mike Browning (24893)
    Hi Gary,
    My GM Engineering Standards manuals provide no information for GM hardware with part numbers beginning with "3" such as #3797244 bolts.
    Mike
    Mike------
    Such bolts are manufactured to a Chevrolet specification, not a GM-wide specification. Thus, they are usually not shown in GM engineering specifications.
    • Gary B.
      • February 1, 1997
      • 6979
      • Mike B.
        • July 31, 1994
        • 838
        #18
        Gary,
        Rich Pasqualone has really come through for me with previous orders by him. He really knows his hardware. Glad you found some nice examples through him of this bolt #3797244.
        Mike
        • Mike B.
          • July 31, 1994
          • 838
          #19
          Mike------
          Thanks Joe,
          I need to expand my library to include those Chevrolet Specifications.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11302
            #20
            Since Jerry brought up this post, and got his answers, but since it further expanded with more info, I just so happened to find a box of original hardware from a 67 body off from a few years ago.
            Images with measurements included. I call them #1,2,3,4. #4 being behind the rear wheels.
            #1
            #2(at the firewall)
            #4 (the other one had to bu wizz-wheeled off)
            • Gary B.
              • February 1, 1997
              • 6979
              #21
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11302
                #22
                Gary, When I get home I'll have to check my photos. I have about 3,000 of that restoration on the laptop backup drive.
                Rich
                • Gary B.
                  • February 1, 1997
                  • 6979
                  #23
                  • Leif A.
                    • August 31, 1997
                    • 3607
                    #24
                    Note the #4 bolt in Rich's pictures does NOT have a pointed end like the other three. Me thinks it may be original but not NTFP.
                    Leif
                    • Gary B.
                      • February 1, 1997
                      • 6979
                      #25
                      Leif,
                      I noticed that as well, but if you look closely, it does seem to have a more of a pointed tip than a regular bolt.
                      Gary
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11302
                        #26
                        Gents, Here's the story after seeing my photos of the prep to lift the body off.
                        I had to cut heads off from BOTH #4 bolts to get them out. The longer bolt that I said was #4, is not. It's a Grade 8, and had 2 washers under the head. Now I'm unsure where it came from, but it came from the car somewhere.
                        #4 Left had 2 shims.
                        #4 Right had 6 shims.
                        After cutting the heads of the #4 bolts, the washers were junk so I tossed them along with the cutoff bolts.
                        There were a total of 25 shims under the body. There are 17 shims leftover(a few were stuck together in the photos), but I recall I used several media blasted refinished shims back on the frame along with the repro LIC kit. I replicated the original shim count going back on.
                        Here's my shim map. 25 total.
                        Here's a photo of the #2 bolt when I removed it. I think I'm missing those two convertible-only #2 mount bolts in my collection because I may have reused them on the car since they're hidden. I can't recall if the kit I had included them. Maybe not and the reason I reused the originals.
                        A few more photos of the bolts.
                        I'm still uncertain where that Grade 8 came from now, but definitely not the #4 mounts. It's tip is flat as you can see it standing up by itself in the center of the photo.
                        • Gary B.
                          • February 1, 1997
                          • 6979
                          #27
                          Rich,
                          Even though you have one unidentified bolt, your documentation is impressive.
                          Gary
                          • Bob J.
                            • December 1, 1977
                            • 713
                            #28
                            Rich,would you mind measuring the washers?
                            Thanks,Bob
                            • Gary B.
                              • February 1, 1997
                              • 6979
                              #29
                              • Richard M.
                                Super Moderator
                                • August 31, 1988
                                • 11302
                                #30
                                Thanks,Bob
                                Sure Bob, I've a a date back in the shop tomorrow so I'll get the ruler and caliper out then. I'll get OD, ID, and thicknesses.
                                Edit... Gary I'll measure everything I have, except for those thin ones at #4 which I hacked to pieces with the cutoff wheel.
                                I do remember a thread some time ago talking about these washers too. I'll poke around the archives later.
                                Rich
