Bolt Size for #4 Body Mount - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    #31
    Re: Bolt Size for #4 Body Mount
    Looking at my photos in that earlier post, geesh that frame looked ugly. I remember the guy that sold the car to my friend said to him something like..... "The chassis is just as nice as the body of the car." Don't think so.
    I forgot how many hours I put into that frame. Fun to see Before & After.
    After
    • Bob J.
      • December 1, 1977
      • 713
      #32
      GARY, If possible, I'd like to get the washer measurements for all the washers.
      The bolts I pretty much figured out but not the washer sizes.
      Take care,Bob
      • Bob J.
        • December 1, 1977
        • 713
        #33
        Sure Bob, I've a a date back in the shop tomorrow so I'll get the ruler and caliper out then. I'll get OD, ID, and thicknesses.
        Thank You, Bob
        • Gary B.
          • February 1, 1997
          • 6979
          #34
          Bob,
          The two sizes of plain washers stored with the body mount bolts from my ‘66 have the following dimensions:
          Large: OD=1.90”; ID=0.434”; th=0.12”
          Small: OD=1.125”; ID=0.46”; th=0.12”
          (I wouldn’t trust the 2nd number after the decimal point because of rust.)
          Those are very close to the specs for GM 3760866 (large) and GM 3790768 (small) that are called out in the ‘66 AIM. But ‘67, or ‘63-‘65, might be different since at least one of the AIM part numbers for one washer is different for some C2 years. We’ll see what Rich comes up with for ‘67.
          Gary
          • Bob J.
            • December 1, 1977
            • 713
            #35
            Thanks, Gary
            Those numbers are just what I needed.
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11302
              #36
              Here's some research I did this morning to supplement our bolts and washers.
              Bob here are some more data points for you regarding the 1967 hardware I have here. Sorry for the hen-scratching. I also did some AIM comparisons, 1963, 1966, and 1967 with some notes.
              First, more measurements. Hope they're readable. If not I'll redo them darker.
              1967 Washers:
              Edit: 12/1 AM - Replaced photos as I goofed up on one of them it was not centered on the measurements. Also zoomed in for clarity.
              Here are the AIMS.
              1963
              1963
              1966
              1966
              1967
              • Leif A.
                • August 31, 1997
                • 3607
                #37
                Rich and Gary,
                As you're both very aware, AMK products can be (sometimes) useful for specs on hardware. From their website:
                The #3772263 bolt...
                Hex Flange Bolts 3/8 - 1/27/16-14 X 2 5/8 GR5 FLNG BOLT "A" PHOS. Phosphate & Oil(ONF) 3902232 (sim)
                And, then the #3790768 small washer...
                Washers - Flat .46 to 1.0 ID.46 ID X 1.12 D X .12 TK FLAT WA PHOS. Phosphate & Oil(MWZ) 3790768
                Leif
                • Gary B.
                  • February 1, 1997
                  • 6979
                  #38
                  • Bob J.
                    • December 1, 1977
                    • 713
                    #39
                    Rich, thanks for the washer measurements. I had no problems reading them.Bob
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11302
                      #40
                      You're welcome Bob. BTW, I edited my earlier post with better and zoomed in images for easier future reference.
                      I also added some nut measurements(NO, not my hat sizes! lol).
                      They were all 7/16-14 threads, but some had different wrench sizes. See notes at right side of page here...
                      Anyone else ever have different ATF nut widths? These would have been at the #1 mount at the firewall as the #4 nuts were rust welded to their bolts when I cut them off.
                        • 43193
                        #41
                        [ATTACH=CONFIG]119836[/ATTACH]
                        Rich------
                        If I encountered so much heavy corrosion in the fasteners, I'd be worried about the rest of the frame.
                        • Richard M.
                          Super Moderator
                          • August 31, 1988
                          • 11302
                          #42
                          Rich------
                          Joe, I restored the frame ~8 years ago. A L71 convertible. Except the 2 #4 bolts that were very badly rusted, the others came out easily. The frame was good and I repaired or replaced sections that were marginal. The inside box channels had some scale and I removed it and zinc coated then blacked it out.
                          I replaced both rear #4 frame mounts, Differential crossmember gusset that was cracked(common on BB's), End Caps, etc. You may remember it. Here.
                          Now the next one I did, a '66 convertible, the frame was so bad that after I took the body off(it took a entire day to get the 8 body mount bolts out) and stripped the frame, it cracked at the kick-ups as I was hauling it out back. It all started when the owner walked out into his garage and saw gallons of fuel on the garage floor "inside" his house! The fuel line was rusted out. I got a reproduction frame for that one. This One.
                          • Gary B.
                            • February 1, 1997
                            • 6979
                            #43
                            …They were all 7/16-14 threads, but some had different wrench sizes. See notes at right side of page here...
                            Rich,
                            The #4 nuts were large square nuts captured in cages, I believe.
                            The #1 nuts changed from GM 124573, which were zinc, 5/8” AF, to GM 9418897, which were black phosphate, 11/16” AF, with an AIM revision date of 10-27-66. So, early MY ‘67 cars would have the 5/8” AF nuts, and later MY ‘’67 would have the 11/17”. (The exact same part number change happened with the majority of bumper nuts during the ‘67 model year.) I wouldn’t be at all surprised to find some ‘67s with a mix of these two AF nut sizes at body mount #1 around or even several months after the 10-27-66 revision date.
                            Ah, but I see you list the AF sizes as 9/16 and 5/8. Are you sure they aren’t 5/8 and 11/16?
                            Gary
                            • David B.
                              • March 1, 1980
                              • 687
                              #44
                              Nut 9418897 is 7/16-14 GM 4435-M code A spec. phos. coated, oil treated & 72 hr. salt spray.
                              • Richard M.
                                Super Moderator
                                • August 31, 1988
                                • 11302
                                #45
                                Originally posted by Gary Beaupre (28818)
                                Rich,
                                Gary
                                Gary, You were right. I had them wrong. So this March '67 had a mix at the #1 mount.
                                Thanks David.
