Decklid Spring Replacement for a C2 - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1273
    One of my decklid springs was broken and I was thinking, it was going to be a major problem. So I searched the best way to replace these springs. It turned out to be a relatively easy job. Actually, the hardest part was getting the hinges out. There are two bolts to the rear and one in the center of the hinge. I used the process where I would put the spring on a floor jack and spread it to the approximate correct length. Then I put wooden wedges between the coils and then released the jack. I then slipped the expanded spring onto the hinge and removed the wedges. I took the other hinge off the same way with the wooden wedges and re-installed it the same way. Hope this helps!
  • Thomas N.
    • July 31, 2002
    • 387
    Re: Decklid Spring Replacement for a C2
    I've used popsicle sticks in the past also. You can get a pack at the dollar store, and put multiple sticks in to fill in the space.
    NCRS New England Chapter Chairman 2022, 2024
    N E Regional Chairman 2024
    1967 Corvette Convertible Under Restoration
    1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
