I've made a prototype lighter fuse holder for the 1963 to 1966 era. This allows use without modifying the Main harness and can be easily removed for judging if needed. Just don't forget to reinstall it asap to protect the circuit and the car.
These lighters use a special bullet pin terminal for power. Ground comes from the housing mount to the cluster. The main lighter harness clip is a unique design and simply pushes onto the pin terminal.
Here is a typical 3 prong lighter socket and pin terminal.
1967 shown(Orange feed wire from fuse panel Courtesy Lamp fused circuit).
1963 to 1966 similar but the feed wire is Red and is sourced directly from unfused Bat+ power.(see below)
Here is a 1963 configuration. Note the Red wire. It is unfused and always powered. (Photo courtesy from Fred H's 1963)
On the lighter socket, the pin is threaded onto the power stud.
Separate loose parts shown from a different defective(rusted) lighter socket to for reference. The threaded barrel pin terminal is upper left.
Here is the pin and reference dimensions.
The harness clip is a special type which may be difficult to acquire. It simply pushes onto the barrel pin and is locked into the pin groove.
Splicing in a fuse to the harness is easiest, but here's another method to fuse the lighter if you don't want to cut the harness. The benefit is if your car is being judged, simply remove the fuse adapter. Unscrew the barrel pin from the adapter, then reinstall it on to the lighter, and connect the standard harness clip back on to the lighter barrel pin.
Here are typical fuse socket assemblies I've had for years. They use blade fuses and are rated 32V @ 20 amps. Round glass fuse holders(upper left) will work as well, but ensure they are rated for at least 20 Amps.
The barrel pin inner diameter thread and stud is #8-32. I had some brass #8-32 screws in my brass hardware collection. I cut the screw heads off and milled holes in the center using my mill.
This hole will accept solder for the fuse holder wire on one end. The barrel pin gets unscrewed from the socket then screwed onto the fuse wire end screw.
The other end of the adapter will screw onto the stud of the lighter socket. I had some 1/4" brass stock(machine screws that I cut the OD threads smoother on my lathe) and drilled and tapped the center 8-32. The end of this will be soldered to the other end of the fuse holder.
This then threads onto the lighter socket stud, from where you removed the barrel pin.
Here is the completed prototype. I will add some rubberized insulation tubing to each end.
I use this small butane torch for soldering the wires to the brass couplers I made.
Here's the completed adapter with details of the ends. I added heat shrink and a rubber insulator at the harness clip end and heat shrink at the lighter housing end.
1028231308_resized.jpg1028231331_resized.jpg1028231335_resized.jpg1028231309_resized.jpg1028231333_resized.jpg1028231831_resized.jpg
The Pre 1963 Corvettes used a flat terminal which screws onto the stud so those fuse adapters are easier to make. The fuse holder will have one male and one female flat blade terminal on each end. Details for C1 fuse points can be found in a PDF document in our Documents Sticky Here.
C2 left, C1 right.
Rich
C2 left, C1 right.
Rich
