66 hood support mounting plate - NCRS Discussion Boards
  • Dennis C.
    • June 30, 2002
    • 884
    Re: 66 hood support mounting plate
    There are some good suggestions offered above. I would add, after using a Dremel to flatten the broken drill bit, try one of these bits:
    They are designed to drill through hardened steel.
    • Dan M.
      • February 1, 2000
      • 97
      I have a dremel tool that's a great idea as well. I'll try that and see if I can get it flattened out. Maybe even make a small depression to get the bit started in the center.
      Dennis I'll have a look at those bits. Haven't seen those before, have you used them successfully? Not inexpensive but if they work....
      Tks guys
      • Dennis C.
        • June 30, 2002
        • 884
        #18
        Tks guys[/QUOTE]
        Yes, I have successfully used them to drill out broken drill bits. You need to follow their recommendation for RPM's while using the bits.
        They attend several trade shows and their demonstrations use these bits to drill holes in hammer heads, files, ceramic tiles, and other "hardened objects".
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11302
          #19
          Dan, Good luck with the Dremel. Have a drill handy right away after the grind on it, since it'll be really hot from the grinding which may help.
          Too bad they don't sell those bits individually.
          Rich
          • Dan M.
            • February 1, 2000
            • 97
            #20
            Ok then, probably worth the investment.
            Im sure it won't be the last broken bolt I have to drill out!
            Tks Dennis
            • Dan M.
              • February 1, 2000
              • 97
              #21
              Will do tks
              • Dennis C.
                • June 30, 2002
                • 884
                #22
                Rich
                If you are talking about Bad Dog Tool Bits, they do sell bits individually.
                Bad Dog Tools: Find the multi-purpose drill bits you need. Durable, USA-made bits for any job, guaranteed for life. Shop now!
                • Brian M.
                  • November 1, 1994
                  • 119
                  #23
                  Brian McIntyre
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11302
                    #24
                    https://baddogtools.com/z-loosesingl...ose-drill-bits
                    Thanks Dennis! My wish came true!
                    • Dan M.
                      • February 1, 2000
                      • 97
                      #25
                      Made some minor progress with the dremel tool and an aluminum oxide bit. It definitely works on the hardened steel and created enough of a depression to center a bit. Tried my cobalt bits and barely made a dent. The bad dog bits would be worth trying I think. Thought I might order a couple bits for about $15 total, they want $40 to deliver. Not to sound cheap but that's annoying.
                      So I'm off to the hardware store to pick up a few more alum oxide bits for the dremel to see if I can improve on what I've got so far.
                      Probably end up ordering the bad dog bits as well.)
                      • Gary B.
                        • February 1, 1997
                        • 6979
                        #26
                        Dan,
                        In between grinding and drilling sessions I think it would be good to continue to apply something like Kroil Oil. My fear is that the next attempt at using an Easy-Out will wind up with another broken Easy-Out. And obviously use the largest diameter EasyOut possible.
                        Gary
                        • Dan M.
                          • February 1, 2000
                          • 97
                          #27
                          Yes I agree, I'll see if I can do that without getting sloppy about it. I worry about getting oil on and into the fiberglass.
                          • Dan M.
                            • February 1, 2000
                            • 97
                            #28
                            Never heard of that, I'll check it out. There is a good machine shop in town I can ask. Tks
                            • Gary B.
                              • February 1, 1997
                              • 6979
                              #29
                              Dan,
                              I agree about not getting the Kroil Oil or equivalent on the fiberglass. Maybe apply it with a Q-tip.
                              Gary
                              • Dan M.
                                • February 1, 2000
                                • 97
                                #30
                                Ha yes that's exactly what I did. Tks Gary
