65-66 Power Antenna Question - NCRS Discussion Boards
  • Jim D.
    • August 31, 1997
    • 58
    Can someone tell me the height of the power antenna mast when completely down and up?
  • E S.
    • December 29, 2008
    • 451
    Re: 65-66 Power Antenna Mast Length
    Hi-Pocket guide says "about 30 inches" for optimum FM reception
    • Jim D.
      • August 31, 1997
      • 58
      Does anyone know how to unseize the top portion of the antenna. I have an antenna that goes up and down but not all the way as the top portion of mast will not move.
      • Bill M.
        • 1317
        • Don H.
          Moderator
          • June 16, 2009
          • 2236
          Re: 65-66 Power Antenna Question
          Bill- if you care to meet me right now in the Test Forum, I will walk you through the steps.. It's EZ
          • Stephen L.
            • May 31, 1984
            • 3148
            In looking at multiple photos of 66 vettes it appears the antenna does NOT retrack completely, but remains about a foot above the fender surface, probably due to the limited vertical space available under the fender surface for retraction........
            • Don H.
              Moderator
              • June 16, 2009
              • 2236
              You're correct Steve, about 13 1/2 " above the deck is as low as she goes.
              • Bill M.
                • 1317
                • Bill M.
                  • 1317
                  Jim Just installed antenna on friends 66. Thanks Don.
