Best laid plans!
After having my 66 aligned for the first time after reassembly. and having the steering wheel perfectly at 3-6-9 ,I went to install the horn assembly and realized the steering wheel was screwed into the wrong holes. When realigned to allow for the 3-screw holed horn ass. to screw into the hub, it points to 4-7-10!
So, my question is this :Can I just pull the hub and steering wheel with a wheel puller and realign it, or do I also have to be aware of where the canceling cam position is , thus having to realigning the steering from the rag joint up ?
