I had new bushings put in my strut rods and now I'm trying to re-install them. I am following the shop manual procedure. The car is on my lift that has the suspension fully unloaded- the wheel are up off the ground. After installing the inner end to the bracket loosely attached to the differential, as per the manual, the wheel end is not even close to going in. What proceedure do you all use to get them in? What am I missing?
Jeff
Jeff
