I replaced the fuel pump on my 67 427/400 car with a AC logo 40482. The prior pump did not have the logo and was leaking. When it was top-flighted it had a deduction for the non-logo pump. When I removed the rubber fuel hose from the pump I got a surprise in the form of a tiny red spray extension tube inside the hose, the type used on WD40 or other spay cans.
In the process of looking for the correct rubber hose replacement, I found that this hose had been updated to a molded type (S-shaped) on subsequent years and the reason was to avoid kinking. I realize that for 67, the molded hose would not be correct.
Finally, if there was a potential for kinking, would it be a bad idea to place a small diameter solid SS wire in the hose to maintain the shape or am I just being overly cautious?
