Grade 7 bolt - NCRS Discussion Boards
Grade 7 bolt
  • Gary B.
    • February 1, 1997
    • 6979
    Grade 7 bolt
    Did GM ever use Grade 7 bolts with 5 lines on the head like the one below on a C2 or C3?
    Gary
  • Mike B.
    • July 31, 1994
    • 838
    Re: Grade 7 bolt
    Yes, on my '66 427 the harmonic balancer was attached by a grade 7 "FC" head mark bolt and both my '66 BB and '65 SB had grade 7 "P" outer rear spring long bolts originally installed from the factory.
    Mike
    • Gary B.
      • February 1, 1997
      • 6979
      • Mike B.
        • July 31, 1994
        • 838
        Re: Grade 7 bolt
        Gary,
        A good buddy of mine recently purchased a set of the "P" grade 7 outer rear spring bolts. I'll post a shot of them when I get home. I've never seen a set as pristine as the ones he just found. Very jealous.
        • Mike B.
          • July 31, 1994
          • 838
          Re: Grade 7 bolt
          Pretty hard to find a set of these P-bolts in this shape. I'm green with envy. Still hunting a nice pair for my '66.
          • James W.
            • December 1, 1990
            • 2640
            Re: Grade 7 bolt
            I have those original bolts on my '65 rear spring.
            [ATTACH=CONFIG]120097[/ATTACH]
            • Gary B.
              • February 1, 1997
              • 6979
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11302
                Re: Grade 7 bolt
                Do we know the GM Part number and application/"where used" for any of these bolts?
                I'm wondering if suppliers ran out of Grade 5 stock and shipped these instead.
                • James W.
                  • December 1, 1990
                  • 2640
                  Re: Grade 7 bolt
                  The grade 7 bolts I have installed on my late '65 trailing arm to rear spring were p/n 3831585 in the 1965 AIM.
                  James
                  • David B.
                    • March 1, 1980
                    • 687
                    Re: Grade 7 bolt
                    Rich,
                    GM grade 7 bolts & screws 1/4' thru 1 1/2" are designated GM-290-M roll threaded after heat treat, as noted they are ID by 5 lines. GM grade 5 bolts, screws & studs #6 thru 1", 1" to 1 1/2" are designated GM-280-M as you know have 3 lines. It is highly unlikely allowed to be substituted in assembly process unless Engineering approved.
                    • Gary B.
                      • February 1, 1997
                      • 6979
                      • Michael G.
                        • November 12, 2008
                        • 2155
                        Re: Grade 7 bolt
                        Normally, an engineering change would have been necessary, but candidly, plants tended to substitute parts first and then ask for permission later, so you might see a substitute in instances where the design parts were in short supply or had a quality problem.
                        • Mike B.
                          • July 31, 1994
                          • 838
                          Re: Grade 7 bolt
                          Gary,
                          Here's the grade 7 "F-C" big block harmonic balancer mount bolt & hardware. These are parts from a '66 427 with a build date of December 7th, '65. My December 1st built car's exact same bolt was mashed a bit by bubbuh using a mallet there. This one's a better example. Other folks on the TDB have previously reported this same head mark on this bolt for '65 396 cars.
                          Mike
                          '65-'67 Harmonic Balancer Bolt & Washer (2).jpg'65-'67 Harmonic Balancer Bolt & Washer (3).jpg'65-'67 Harmonic Balancer Bolt & Washer (4).jpg
                          • Gary B.
                            • February 1, 1997
                            • 6979
                            • Richard M.
                              Super Moderator
                              • August 31, 1988
                              • 11302
                              Re: Grade 7 bolt
                              Originally posted by David Bartush (3288)
                              Rich,
                              Thanks David, I understand. But on the line I think it's possible they did whatever was needed to make the cars and not stop the line. Maybe not in this case, true. But I still need to find a detail specifically showing the part# James posted is spec'd as a Grade 7(GM-290-M), not Grade 5(GM-280-M).
                              James
                              Thanks James. Now on the hunt..... gmpartswiki was no help but I have some other big books in the shop I'll check when time.
                              If there are any other part numbers relating to this issue please post them and I'll look those up too.
