1971 Headlamp Bezel Screw Spec Info - Help! - NCRS Discussion Boards
  • Ray K.
    • April 30, 2005
    • 401
    Can anyone help identify the specifications for the 1971 headlamp bezel screw, GM# 9427748?
    Looking for the machine thread size and length (it's definitely chrome).
    In the 1971 AIM it's item #9, shown in UPC 12, Sheet A4).
    Appreciate it if someone can share the spec info for me. . . . .
    Ray K ((#43777)
  • John S.
    • June 15, 2015
    • 505
    Re: 1971 Headlamp Bezel Screw Spec Info - Help!
    Ray, just double checked my 73 AIM and it shows the same P/N, here’s a shot of one of my originals. #8-32 x 3/8” flat oval Phillips head. 3/8” length measured from top/outer edge of the flat head not including the height of the oval. Hope this helps.
    1973 L82 M21 4 Speed, very original and well documented driver/survivor
    NW Chapter Member, 2016 Bend Regional Top Flight
    73/74 TIM&JG 3rd Edition Revision Team Member
    • Peter H.
      • April 1, 1980
      • 223
      Good Evening Ray. Corvette Central Shows Part # 343060 H/L Bezel Screws @ $5.85. Has 4 Of Your Screws. Peter Hannigan 🇨🇦
      • Mike E.
        • February 28, 1975
        • 5134
        Originally posted by Peter Hannigan (3522)
        Good Evening Ray. Corvette Central Shows Part # 343060 H/L Bezel Screws @ $5.85. Has 4 Of Your Screws. Peter Hannigan 
        They are not correct.
        • Ray K.
          • April 30, 2005
          • 401
          John,
          Thank you for providing a picture of you '73s headlamp bezel machine screw. I'm a little surprised by its length, I thought it would be a little longer.
          Peter,
          Appreciate your "heads-up" on Corvette Central's headlamp bezel screw kit (#343060). Looking at it, I'm not sure why they include the collets for the bezel's side attaching screws. There's no mention of any collets on these side screws in the 1970 - 1972 6th Edition Technical Information & Judging Guide. Do you know if they possibly were used on other model year bezels?
          Mike,
          It seems like that you may have purchased Corvette Central's headlamp bezel kit previously. Can you let me know what's wrong with the machined screws? And, do know of someone who m ay be currently selling the "correct" ones?
          Appreciate all of your help . . . .
          Ray K
          • Mike E.
            • February 28, 1975
            • 5134
            Originally posted by Ray Krawczyk (43777)
            John,
            Peter,
            [ATTACH=CONFIG]120381[/ATTACH]
            Mike,
            Ray K
            Ray,
            My recollection is that CC (and everybody else that has them) sells stainless steel machine screws, while the originals were chrome.
