58 Tail Light Lens Screws - NCRS Discussion Boards
  • Jason P.
    • April 6, 2023
    • 207
    I purchased the tail light lens screws with nylon washers for my 58 Vette and they don't want to screw in.
    Anyone else had this problem and anyone have a solution?
    Here are the screws I purchased:
    https://www.corvettecentral.com/c1-5...t%26count%3d45
    I don't think I have a thread chaser that small in diameter but then again I don't really see any threads to begin with.
    For clarity, these are the screws that attached the plastic tail light lens to the tail light assembly.
    Jason
  • Mike M.
    • May 31, 1974
    • 8365
    Re: 58 Tail Light Lens Screws
    Fasteners in your photos appear correct heads. If you had your tail light rechromed , that may explain it and then u willi have to tap the lights. Mike mccagh
    • Jason P.
      • April 6, 2023
      • 207
      Thanks but I havent had my tail lights rechromed. I will try again this evening.
      • Jason P.
        • April 6, 2023
        • 207
        I again tried but I am not able to get the screws in. Does anyone know what size the screws are that go into the taillight lens to hold it down? Are they #6-32 or #8-32? The ones corvette central sent me are #8 but it feels like they should be the smaller #6.
        Anyone please help lol. I am at my wits end.
        • Gary B.
          • February 1, 1997
          • 6979
          • David B.
            • March 1, 1980
            • 687
            Look in Grp. 2.697 of 58 parts book. 912048 appears to be the correct screw #8-32 x 5/8
            • Jason P.
              • April 6, 2023
              • 207
              I measured the screw and it is a #8-32 x 5/8. I am thinking maybe I need to run a #8-32 tap through it to clean/cut the threads.
              Here is a picture I took zoomed in x10 on my phone.
              What are your thoughts about running a tap through it?
              Thanks in advance!
              Jason
              • Jason P.
                • April 6, 2023
                • 207
                I don't have a parts book. Where can I get one of these?
                • Ian G.
                  • September 3, 2007
                  • 1114
                  eBay will often have them.
                  • Joe M.
                    • April 30, 1990
                    • 1338
                    I have experienced the problem on my 1960 with the original screws. The screws will go in if you insert them at the correct angle. Don't force them.
                    • Jason P.
                      • April 6, 2023
                      • 207
                      Thanks everyone. I was able to run a tap through them and then the screws worked perfectly.
                      I have another question. I purchased a tail light seal from Corvette Central and was confused as to how it was used. Looking in the AIM, I don't see it referenced anywhere but I think it is supposed to go in between the plastic tail light lens and the lens assembly to create a watertight seal.
                      If this seal is supposed to be used, should i apply some contact cement or something on the seal/gasket so that it will stay in place when trying to screw on the lens? The rubber gasket/seal won't stay in place otherwise.
                      I saw someone else had a post asking the same question and they never got a response.
                      Thanks in advance!
                      Jason
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11302
                        Jason, Yes, you'll have to use some black 3M w/strip adhesive.
                        Just a little on the housing perimeter every few inches and around the upper and lower curves. Then in the same spots on the gasket. Again, not a lot.
                        Then let the glue kick-off for a few minutes. This is important as it's contact cement.
                        Then carefully apply the gasket to the hhousing.You can put some masking tape pieces across in several place to assist. It should stay put. When it's stuck and holding the curves. Remove the tape.
                        Then attach the lens with the screws, just snug. Don't go too tight.
                        I always try to align the slots of the screw heads parallel with the vertical length of the lens for a neater appearance. It's just a byproduct of my antique mahogany boat building process which uses slotted screws for all hardware, engine cover hinges, etc.
                        Plus it'll make the car go faster due to less wind resistance.
                        P.S. Cute puppy in the background.
                        • Jason P.
                          • April 6, 2023
                          • 207
                          Richard, thanks for the great info!
                          • Gary B.
                            • February 1, 1997
                            • 6979
                            That brought a smile to my face!
                            Gary
