How to clean 69 sun visors? - NCRS Discussion Boards
  • Michael C.
    • January 9, 2013
    • 328
    My 69 comfort weave sun visors (originals) are in good shape. They have been off the car a long time and have some dust in the weave and some discoloration from oily hands (body oil not motor oil). I wonder how aggressive I can get with cleaning. A light spray with a Dawn solution and scrubbing with a tooth brush achieves some improvement. Hard rubbing with a cloth moistened with isopropyl alcohol helps, but is tedious and I'd like better.
    Does anyone know what lies beneath the vinyl weave? I wonder if something stronger than a spray with Dawn and light scrubbing might cause more harm than good.
    Mike
  • Richard K.
    • April 1, 1988
    • 207
    Re: How to clean 69 sun visors?
    Brown jute padding is beneath the weaved vinyl fabric.
    • Joseph W.
      • February 20, 2022
      • 368
      • Owen L.
        • September 30, 1991
        • 838
        I've had good success using "Scrubbing Bubbles" foam bathroom cleaner. Spray it on, wait a few minutes, work it into the texture with a soft bristle brush, and wipe clean with a sponge.
        • Michael C.
          • January 9, 2013
          • 328
          Thanks for the replies. I was mostly concerned about causing the inner material to deteriorate, but it sounds like I can be a little more aggressive.
          • James G.
            • August 22, 2018
            • 783
            After consulting with an oriental carpet cleaner.
            I used a wet dry vac and boiling hot water in a pump up sprayer with some oxy clean and a little fabric softener, which help act as a drying agent.
            Spray and drag the vacuum at the same time...
            James A Groome
            1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
            1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
            My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
            Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
