1962 340hp by-pass hose water pump to expansion tank - NCRS Discussion Boards
  • Dino L.
    • February 1, 1996
    • 694
    Does anyone know what catalog companies sell the correct by-pass rubber hose? I am having no luck calling around. Also does anyone know the spec on the od and id that I can use to get one from an auto part store?thanks for your help.
    Dino Lanno
  • Harry S.
    • July 31, 2002
    • 5258
    Re: 1962 340hp by-pass hose water pump to expansion tank
    You have a part number available to compare against a 63-67?
    DocRebuild 34 years supplying authentic 1953-1982 Corvette reproduction parts. We develop & market quality replacement parts using original samples, original blueprints and modern material and methods. NCRS No Correctly Restored Stingrays C1 C2 C3 oOSOEZ, No zip. No bling.
    • Mike E.
      • February 28, 1975
      • 5134
      It is just a sort piece of heater hose, if you are talking about the hose from the expansion tank to the water pump. Pretty sure it is 5/8 hose.
      • Dino L.
        • February 1, 1996
        • 694
        Thank you Harry and Mike, appreciate the info!
        Dino Lanno
        • Carl R.
          • October 31, 2018
          • 63
          HI Dino, The hose that you are talking about is 10 inches long and 3/4 inch ID. Corvette Central shows this hose on page 38 of there most recent catalog. Part #241305. This hose will have a stripe of ribs running along the length of the hose. Zip has this hose in there Catalog also page 69, part #M-2576. One of these guys should be able to help you out.
          • Dino L.
            • February 1, 1996
            • 694
            Dino Lanno
