�66 switched hot in fuse block - NCRS Discussion Boards
  • David P.
    • October 26, 2015
    • 49
    On a 1966, should the ACC terminal in the fuse block be hot when key is in ACC and/or RUN? The brown wire at the ignition switch is hot when key is in the ACC position. Per the wiring diagram, this terminal should be tied to the ACC key position.
  • David P.
    • October 26, 2015
    • 49
