Welded nut broken and spins - HELP - NCRS Discussion Boards
  • Jason P.
    • April 6, 2023
    • 207
    One of the nuts that are welded on to the back of the rear bumperette broke and just spins when I try to take the bolt out.
    There isn't really any room because of the curve and angle to get anything on it to clamp it down.
    I don't think I can stick my mig gun far enough in it to zap a spot weld on it.
    Anyone have any cool tricks for situations like this?
    TY,
    Jason
  • Jason P.
    • April 6, 2023
    • 207
    Re: Welded nut broken and spins - HELP
    Unless anyone has any tips or tricks I should try I guess I an just grind the head of the bolt off and then use a rivnut.
    • Jeffrey S.
      • April 1, 2004
      • 133
      Well you could cut one edge of the bracket and heat and bend the other side / to expose the offending nut / then weld a new one in place . Then reheat and bend the bracket back into the original position and weld that edge . A little work but a quality outcome. / I only suggest this because you mentioned you have a mig welder so I assume you have the skills needed to complete the job as described . Hope this helps Jeff
