mark of excellence foil sticker on 67 doors - NCRS Discussion Boards
  • Jeffrey S.
    • April 1, 2004
    • 133
    I took these off the doors before paint and now I would like to put them back on . Do any of you know what kind of glue I can use that won't eat the paint underneath . Thanks in advance Jeff
  • Bill M.
    • 1317
    Re: mark of excellence foil sticker on 67 doors
    I had my 67 painted last year and put new emblems on. But if you want to use the originals I would try the weatherstripping glue
    • Donald S.
      • August 31, 1996
      • 186
      I used doubled sided tape that I got from a friend that manages a body shop. As I recall, it was very thin film that was a pain to peel but it worked and you can't see it along the edges. Don
      • Owen L.
        • September 30, 1991
        • 838
        3M Adhesive Transfer Tape. It behaves like a double-sided, but is just the adhesive without any core substrate. It's very thin but also very tenacious. I'll have to look up the type # I use and will post later -- it's #465. (3M makes a number of different mil thickness versions of the tape.)
        • Jeffrey S.
          • April 1, 2004
          • 133
          Thanks fellas this is what I was looking for . Jeff
          • Steven B.
            • June 30, 1982
            • 3976
            Helped a friend years ago and he used two adhesives, the 3M double sided as mentioned and also 3M spray adhesive.
            • Enzo C.
              • January 12, 2012
              • 533
              I removed and reinstalled the original foil stickers
              8 used contact cement on both surfaces and adhered perfectly
              Dont use repops as the color is off and not correct
              Enzo Colosimo
              Ncrs Ontario Chapter Chairman 🇨🇦
              ENZ-Z06/67
