73-74 LS4 EGR Valve Gasket Technical Question? - NCRS Discussion Boards
  • George H.
    • March 9, 2017
    • 180
    Re: 73-74 LS4 EGR Valve Gasket Technical Question?
    George------
    This what the original GM gasket looks like:
    • George H.
      • March 9, 2017
      • 180
      Thanks Joe. I purchased the wrong replacement gasket and installed it. The picture you posted is just like the one that I took off the car. The one I purchased and installed has the two extra holes in it. It fits, but, I now know its the wrong one. I'm stilll not sure why there are two small 1/4" holds in the gasket, just like the holes in the valve? Must be the mounting base was a standard part jused on other model EGRs valves and the holes get coverd up on the BB engines. Hope I don't break off one of the 3 tabs on the French lock removing the bolt again.
      • Jimmy P.
        • June 24, 2014
        • 1695
        Jimmy
        1973 Convertible
        L48,M20,N40
        Mille Miglia Red/Oxblood
        • George H.
          • March 9, 2017
          • 180
          Thanks Jimmy for the feedback. I just found the correct style EGR gasket at Zip Corvettes.
