I have a 1963 C-2 Coupe, with a 327/340 hp engine and 4 speed transmission. Per the NCRS Shipping Data Report, the GM official production date of the car was May 5, 1963. Based upon casting and stamped information, the differential is from a 1976 Corvette, 3:08 ratio, with positraction.
I am seeking to replace the differential with one that is casting number, casting date, and assembly date consistent with the car's production.
I have located a differential for sale with a Feb 2, 1963 casting date, and a stamped differential ratio of CB, which, according to my NCRS 1953-1967 Corvette Specifications Guide translates into a 3.36:1 Positraction Manual Transmission or Powerglide Transmission.
My questions:
a) What is an acceptable date range from the time the differential housing was cast , differential was assembled and the car was produced. ?
b) The CB designation as described in the NCRS Specifications Guide identifies "Manual Transmission or Powerglide. There are separate designations (CC,CD,CF,CJ), for Positraction 4 Speed transmission. Does this mean the Manual Transmission identified in the CB, is ONLY the 3 speed (standard) transmisson, and does not apply to manual 4 speed transmissions.
c) Did 1963 327/340 hp cars have to be ordered with 4peed transmissions and or positraction, or could one have gotten a 3 speed manual, non positraction car with a 327/340 hp engine ?
Thank you for your wisdom.
Hank Sarno
NCRS# 22026
My questions:
Hank Sarno
NCRS# 22026
