58 Courtesy Lamp Question - NCRS Discussion Boards
  • Jason P.
    • April 6, 2023
    • 207
    The 58 I am restoring doesn't have any areas in the door jams that appear to have been cut out to accept the courtesy lamp. I am assuming that the courtesy lamp/light was an additional option buyers could choose.
    The car does have the cut out above the radio section that could have help a courtesy lamp. I am thinking that all 58 Corvettes had the cut out for the courtesy lamp above the radio. Those that did not have the courtesy lamp option would of had a courtesy lamp delete blockoff plate.
    Are my assumptions correct and since my car doesn't have the lights in the doors jams, I should use a courtesy lamp delete blockoff plate to cover up the hole above the radio?
    Thanks in advance.
    Jason
  • Mike E.
    • February 28, 1975
    • 5134
    Re: 58 Courtesy Lamp Question
    You are correct on all counts, Jason.
    • Jason P.
      • April 6, 2023
      • 207
      Thanks for confirming.
