I recently bought a 1970 base motor convertible. Originally delivered to California from factory. It has an aluminum heat shield under the q-jet carb. I understand that this was required for cars shipped to California. Are there any other emmission add ons for this car? Thanks
California emissions 1970
Re: California emmisions 1970
Yes. RPO NA9 consists of that heat shield, a special Quadrajet, a charcoal canister, and the vapor lines to connect these to the fuel tank.
It probably also consists of special fittings and no vent on the gas tank; others can confirm.
The 5th digit of the NA9 Quadrajet pn is "5", versus "2" for 49-state. It has an extra vacuum port on the front for the evaporative emissions connection, a sealed front fuel bowl vent, and probably different jetting (the jetting difference is a guess).
A new member posted over the past 2 weeks asking for a photo of a 1970 with its heat shield. You might post a photo there or here.Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
Thanks for the reply. The carb number is 7040502 ET. The fifth number as you said is a 5. The NCRS book list this number as equipment on a 300 base Auto & ECS. This is a 4 speed car. The 4 speed should be 7040513 as I read it. It appears it's not the original carb.
I did find the charcoal cannister. It is plugged as are several vacuum ports on the carb.
I'm posting a photo with heat shield shown. I haven't checked the fuel tank yet.heat shield.jpg
I- Top
I had to pull my carb today to fix a stuck float, I got a good picture of the part number. This is a base motor four speed 49 state car. I'm still trying to figure out all the letters and numbers. 7040213 is the part number.Attached Files- Top
Re: California emissions 1970
Here is my California Emissions (NA9) 1970 with an automatic so with the 502 carb. You will also need the yellow emissions sticker on driver side firewall.
. IMG_5911.jpgRegards,
Brady Como
#42793- Top
Unlike the carburetor shown, the original doesn't have a vacuum port coming out the right side, and has a sealed front fuel bowl vent.Thanks for the reply. The carb number is 7040502 ET. The fifth number as you said is a 5. The NCRS book list this number as equipment on a 300 base Auto & ECS. This is a 4 speed car. The 4 speed should be 7040513 as I read it. It appears it's not the original carb.
I'm posting a photo with heat shield shown. I haven't checked the fuel tank yet.[ATTACH=CONFIG]121344[/ATTACH]
I
Originally, TCS (missing on your car) connects to the vacuum port on the right front (plugged on your car), and ECS connects to the left front port (where your vacuum advance is currently connected).Mark Edmondson
Dallas, Texas
Texas Chapter
- Top
What is the date on your carb? Does it fit the build sequence of your car?- Top
Mike,
Even if the date fits, this one is a non-Corvette Q-Jet assembled from a mixed bag of parts. It has an NA9 vacuum port on the front of the bowl but sports a 49-state airhorn and a vacuum port on the side used for either an AIR system or vacuum operated door in the air cleaner snorkel (which 1970 Corvette Quadrajet engines do not have),Mark Edmondson
Dallas, Texas
Texas Chapter
Justin------
Nope; you could not. All cars delivered to California had the NA-9 "option". GM also specified that it was only available for cars delivered to California.In Appreciation of John Hinckley- Top
