I have decided to convert my canister / cartridge style oil filter on my '66 327/350hp to a spin-on. This is, of course, a reversible process since the conversion kits are simply bolt-on. Which manufacturer of the spin-on oil filter conversion kits is the best based on quality of parts, ease of installation or any other aspect of the product that you deem important? I appreciate your opinions!
Who Manufactures the Best Spin-on Oil Filter Conversion Kit?
Re: Who Manufactures the Best Spin-on Oil Filter Conversion Kit?
Jeffery,
I have installed on my '67 L79 the Trans Dapt 1059 and have been very satisfied for over 12 years. I, also, use a Wix 51061 oil filter.
https://www.amazon.com/Trans-Dapt-10.../dp/B000CPZVVQ
Leif
Top Flight 2017 Lone Star Regional- Top
Leif, I also heard the WIX 51515 is good to use with that unit, thoughts.
These cross reference for a PH-8A on the Trans Dapt 1024 box are:
- Wix 51015
- Wix 51016
- Wix 51085
- Wix 51515
- Wix 51515XP
- Wix 51516
- Wix 51775
- Wix W51515
- Wix WL10170
- Wix WL7096
Skip the first 6 minutes and 38 seconds ---> Installing a Trans Dapt 1024 Oil Filter Adapter On a Small Block Chevy (youtube.com)
- Top
Jeffery,
I have been following your previous post regarding the oil filter leak. I will give you my opinion on the issue and your potential switch to a spin on filter conversion. Firstly, I am the owner of a '65 fuelie so I, too, have a cannister style filter. I have changed oil several times and never had a problem with leaks. Also, about a hundred years ago, when I was a kid, I used to work at a gas station and we did many oil changes and service work. A number of the cars we serviced were Chevys with cannister filters. So, I've had a lot of experience in servicing cannister oil filter cars. The worst problem I encountered was when there were multiple gaskets installed (stacked). We always replaced the gaskets and always removed the old gaskets. When I encountered the multiple gasket situation it was usually a bitch to remove the bottom one as it was very brittle. Anyway, once again, I never had a leak issue when done. I don't know if you found your issue but I suspect the cannister was not seated on the gasket and was offset a bit and up against the block (metal to metal). If it was me, I'd try again as I think the cannister was/is pretty foolproof if done right. Back in the day I did do a conversion and I believe I used genuine Chevrolet parts although I don't recall for sure. I doubt you can get new Chevy parts but Mr. Gasket makes a conversion kit. Check out Summit Racing.
Terry- Top
Jeffery,
TerryMark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
- Wix 51015
- Wix 51016
- Wix 51085
- Wix 51515
- Wix 51515XP
- Wix 51516
- Wix 51775
- Wix W51515
- Wix WL10170
- Wix WL7096
I edited my original post. The Trans-Dapt 1024 has a 3/4" threaded pipe and the filters you list should work with that adapter. The Trans-Dapt 1059 that I have on my L79 utilizes a 13/16" threaded pipe and uses a Wix 51060, 51061 or 51069 filter. I use the 51061 because it is about 1" longer (bigger).Leif
Harry,
- Top
