Removing shock mounts - NCRS Discussion Boards
  • Jim D.
    • August 31, 1997
    • 58
    What's the safest and easiest way to remove rear shock mounts on a 66 big block. These are not rusted on, there on a recently restored vehicle.
  • Leif A.
    • August 31, 1997
    • 3607
    Re: Removing shock mounts
    Jim,
    Remove the cotter pin, remove the castle nut, partially re-install the castle nut backwards (so that the "castles" are facing the mount). Grab a 5# BFH and give the nut a good whack. Should pop right off.
    Leif
    • Bill M.
      • 1317
      I use a non castle nut same way
