Getting close to painting my 63 convertible and have a few questions:
1. What is the appropriate grit paper to use on the primer/sealer so sand scratches don't show? Seems to me lacquer is thinner than modern paints and suspect the build won't fill as much as local painters are used to.
2. How many coats are recommended to provide enough for cut/buff? I was thinking maybe 3 or 4. Don't want to cheese out and have any spots to do over that get sanded through. Back in the day the ultimate show car lacquer paint jobs were referred to as "7 coats of hand rubbed lacquer". I don't want to overkill it like that.
3. Given the number of coats that might be recommended, how much paint should I need using the paint manufacturer's recommended mix of 1:1? the areas to be covered are entire exterior of body, underside of deck lid panel (which I assume should be body color?), and door jambs+sills. No interior parts and not repainting the removable hard top.
4. How long should I wait after painting to cut and buff? It has been said its best to let the car sit out in the sun for "X" days/weeks to let the paint shrink first. What is "X"?
I would have addressed this with the NCRS Body & Paint technical advisor but the latest issue of the Restorer indicates that position is N/A.
(As a historical note: Last time I had it done in 1992 I paid $850 to a small shop for prep and painting. Plus, I provided the Riverside Red DuPont lacquer, which cost me $46/gallon over the counter. I forget if I provided the thinner. The price included prep and paint for the hard top as well. That paint job held up very well and looked very nice...but not perfect. Maybe accidentally factory original quality. I expect I will have to pay a bit more now than I did back then.)
