thread size of the three bar Corvette C2 spinner? Suitable hex nut? - NCRS Discussion Boards
  • Oliver S.
    • December 1, 1999
    • 341
  • Dorsey F.
    • April 11, 2022
    • 32
    Re: thread size of the three bar Corvette C2 spinner? Suitable hex nut?
    How would you replicate the backside taper with a nut?
    • Jim L.
      • September 30, 1979
      • 1805
      Originally posted by Oliver Schoenhaar (33229)
      I’d like to know what the exact thread size of a three bar C2 spinner is. I have only found this information: 2-5/8” - but without threads per inch. Furthermore, does anybody know a source where to obtain fitting center lock nuts (rh, lh - hex type) to temporarily replace the spinners.
      Oliver
      KO spinners are threaded 2-5/8 x 8 with a backside taper of 60*.
      • Oliver S.
        • December 1, 1999
        • 341
        Thanks Jim. Maybe there are some vendors out there offering center lock nuts for other KO wheels , e.g. low rider cars. Background why I want to get such replacements: here in Germany spinners may cause trouble, even when they were original back then. Once there was a replacement aparently went into oblivion.
        https://www.corvetteforum.com/forums...go-away-2.html
        Oliver
        • Gary C.
          Administrator
          • October 1, 1982
          • 17549
          Oliver,
          You can always drill and tap holes in the spinners for set screws. Set screws will keep the spinners in place.
          If the spinners are original, you could always acquire a RePop set to drill and tap.
          Gary
          NCRS Texas Chapter
          https://www.ncrstexas.org/
          • Oliver S.
            • December 1, 1999
            • 341
