C2>Why The Three Holes On Top Of The Frame Cradle? - NCRS Discussion Boards
  • Larry E.
    • 1652
    Just Curious: Why are there 3 holes on the top of the frame cradle just below the Engine Damper
    (Picture Below) Perhaps
    for factory assembly purposes to hold this part? Just a guess. Thanks>Larry
    Larry
    LT1 in a 1LE -- One of 134
    • 15610
    Re: C2>Why The Three Holes On Top Of The Frame Cradle?
    Your "guess" is quite possible. The start of the assembly process was a large fixture that held the frame upside down, and this is how most suspension components were installed. Precision mounting was required because rear toe was set at this point.
    I know John Hinckley had a presentation that described this assembly process, and it might be here on the TDB or at least he discussed it in some threads.
    • David Z.
      • April 1, 2002
      • 181
      Here's an article on chassis assembly by John Hinckley from the Corvette Enthusiast magazine (2006).
      Dave Z
      Dave Zuberer
      • Mark F.
        • July 31, 1998
        • 1468
        Dave Z
        Hi Dave,
        Good read and thank you for posting.
        Do you have access to all of John's Corvette Enthusiast articles ?
        I subscribed to Corvette Enthusiast from the 1st issue on until they ceased publication (can't remember when that was, but it was a good rag...sorry it went away).
        Were pdf's ever made and available via some venue ?
        I can't find anything on the web
        thx,
        Mark
        • Mark F.
          • July 31, 1998
          • 1468
          Originally posted by Larry Evoskis (16324)
          Just Curious: Why are there 3 holes on the top of the frame cradle just below the Engine Damper (Picture Below) Perhaps for factory assembly purposes to hold this part? Just a guess. Thanks>Larry
          Larry,
          My guess is they may have been fixture locating holes when the frame was being assembled by A.O. Smith.
          That crossmember aligns the two frame side rails and based on the bead size; speed; and heat welding created - it needed to be firmly and accurately secured before welding could take place.
          John Hinckley's C2 Assembly Process Presentation (available in the Database of Restoration Documents [DoRD] Sticky Post) doesn’t say anything about those holes – probably because the frame arrived that way and he was only explaining what they did at St. Louis in his presentation. Pictures I have seen of the Frame Upside Down Line (FUDL) don't seem to show those holes filled with alignment pins or anything else I can see - but that's not to say pictures that may have been taken at different stations up, or down the line might have...who knows ?
          Also, we might say after rolloff, delivery and years of driving they may also serve as drain holes to prevent premature rust out of the cradle �� My wife had an MKZ that the cradle rusted so bad it failed PA state inspection, but was replaced under warranty.
          thx,
          Mark
            • 15610
            What's a "MKZ"?
            • Mark F.
              • July 31, 1998
              • 1468
              What's a "MKZ"? Duke
              It was a Ford product (dunno if Lincoln had formally "split off" from them or not)
              thx,
              Mark
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11302
                That pickup looks like mine and that frame looks like the one I did back in '15. BTW it's a '67. Those looks like my trees in the background too!
                HaHa that's funny Larry. I'm glad you used that photo. Must've been from that long build thread I did back then. Gosh that was a long thread with so many photos.
                Anyways, I always wondered about those holes too. Maybe alignment for the chassi build as mentioned, or maybe for the huse metal bending jig at the frame fabrication facilty(AO Smith iirc), or maybe even designed in "vent" holes so the air can pass through too.
                Or all of the above?
                Rich
                • Larry E.
                  • 1652
                  Thanks to all for the response. Another guess from me>Could those holes in anyway
                  "strengthen" this cradle? vs. one with no holes?(By relieving the stress) With all that weight that goes through that area I would
                  think that cradle flexes to some degree even though very small. Maybe we will never
                  know. Larry
                  Larry
                  • Mark F.
                    • July 31, 1998
                    • 1468
                    ...Anyways, I always wondered about those holes too. Maybe alignment for the chassi build as mentioned, or maybe for the huse metal bending jig at the frame fabrication facilty(AO Smith iirc), or maybe even designed in "vent" holes so the air can pass through too. Or all of the above? Rich
                    thx,
                    Mark
                    • Mark E.
                      • April 1, 1993
                      • 4498
                      know. Larry
                      Flanged holes may increase rigidity, but the edge of holes are also prone to fatigue cracks. My guess is they're locating points for a jig or fixture. Double as drain holes too.
                      Mark Edmondson
                      Dallas, Texas
                      Texas Chapter
                      • Bill M.
                        • April 1, 1977
                        • 1386
                        know. Larry
                        The holes are stress risers (increase chance for a crack). My guess is that the big hole accurately locates the crossmember in the jig that welds the frame and the small holes keep the crossmember square to the siderails.
                        • David Z.
                          • April 1, 2002
                          • 181
                          Mark,
                          I just sent you a PM.
                          Dave Z
                          Dave Zuberer
                          • Mark F.
                            • July 31, 1998
                            • 1468
                            Mark, I just sent you a PM. Dave Z
                            Hi Dave,
                            I have no PM from you in my inbox...checked twice over the past 1/2 hour.
                            just click on the email link and send me one if you care to
                            thx,
                            Mark
                            • David Z.
                              • April 1, 2002
                              • 181
                              Email sent but it lost the colored text of messages from John re: his CE articles.
                              Send me an email address and I'll send that info along.
                              The PM turned out to be 396 characters too long so it did not send.
                              DZ
                              Dave Zuberer
