The positive stud on my starter rotates 360 degrees. Are parts available OTC to repair this?
Loose starter solenoid stud
Re: Loose starter solenoid stud
Justin-----
Delco used to offer a solenoid rebuild kit but it's been discontinued for many years.
However, you can still obtain a complete rebuild kit from Standard Motor Products under their part number SS408K. This includes a new cap, contact, and other parts.In Appreciation of John Hinckley- Top
In any event, you'll have to remove the starter then remove the solenoid, disassemble and inspect to determine what new parts are needed. While you're at it why not rebuild the starter, too. As long as the bushings are okay, it's a simple DIY job. The detailed procedures are in the COM, and parts like the shift lever and overrun clutch should be readily available.
Also, the various parts are available in other "brands", like BWD, and are most likely are the same SMP manufactured parts, so if your usual parts store doesn't carry Standard, they can probably cross reference the Standard part number to whatever brand they carry.
Duke- Top
Thanks gents,
I've ordered the kit Joe listed and I'll dive into the starter as well.
I saw a starter heat shield listed in the CSM. I don't remember removing this but it's been nearly 12 years.
Was this standard on Corvettes?- Top
Justin------
Yes, solenoid heat shields were used for both big blocks and small blocks during your year model range. However, they were different for small blocks or big blocks.In Appreciation of John Hinckley- Top
Not the best resolution, but an image from one of the Corvette Parts suppliers:
1969 - 1974 350 Corvette
As you can see, it is multi-faceted. Lots of angles.
Here is the big Block shield. Much different.Bill Bertelli
Northeast and Carolinas Chapters Member
'70 Resto Mod LT-1 w/ partial '70 ZR-1 drivetrain- Top
